Apr 24, 2026 09:13 UTC
RMII configuration for STM32H745BIT6
New question split from this post.
OK THANK  YOU @mƎALLEm , CAN U SHARE THE RMII CONFIGURATION FOR STM32H745BIT6?
mƎALLEm
mƎALLEmBest answer
Apr 24, 2026 10:17 UTC
We don't have CubeMx RMII configuration for that specific part number but you can inspire from what it was implemented in NUCLEO-H743 as it uses RMII mode.
From its schematic:
The LWIP example (unfortunately no ioc file available) where the Ethernet PHY is configured:
https://github.com/STMicroelectronics/STM32CubeH7/tree/master/Projects/NUCLEO-H743ZI/Applications/LwIP/LwIP_HTTP_Server_Netconn_RTOS
You need to reflect the configuration in your CubeMx configuration.
mƎALLEm
mƎALLEmBest answer
From its schematic:
