JSanc.7
Jun 2, 2023 8:59 AM UTC
Is there any manual in the ST page of the differents example projects of one board?
Olivier GALLIEN
Jun 2, 2023 9:13 AM UTC
Hi @JSanc.7​ ,
STM32CubeProjectsList.html provided in the STM32Cube Package lists all project supported per board.
Then for each example you have an associated readme.txt file explaining purpose and how to.
Is that match your request ?
Olivier
waclawek.jan
Jun 2, 2023 10:58 AM UTC
For example, for 'F4, here.
Github won't serve it as html, so you have to download it as raw, and then open locally.
Pavel A.
Jun 2, 2023 11:58 AM UTC
waclawek.jan
Jun 2, 2023 12:06 PM UTC
Hi Olivier,
fancy to write an Article here, perhaps giving links to existing Cubes' apps lists, using the trick Pavel gave above?
Thanks,
@Community member​
Olivier GALLIEN
Jun 2, 2023 12:19 PM UTC
Indeed @Community member​ , the tips given by @Pavel A.​ can likely be well used to ease access of such information.
Idea highlighted/escalated inside ST.
Thank you both.
Olivier
