Apr 3, 2025 4:59 AM UTC
how to use variable in across different cores? how to debug FreeRTOS ?
Now, I am using the NUCLEO-H755ZI-Q board,  Could you share how to solve the issue of using the same (shared) variable in across different cores?
when I try to debug the code of freertos ,It is not going to debug after it enter this line  osKernelStart(); how to debug further. how to know my code is correctly working or not. (i am useing stm32cubeIDE)
kavyammBest answer
Apr 24, 2025 6:16 AM UTC
Thank you for the response. For shared variable, I used hardware semaphore it is working .
for debugging the freertos ,I put a breakpoint for where I need.
Andrew Neil
Apr 3, 2025 9:22 AM UTC
Welcome to the forum.
That sounds like two separate questions. Best to keep to one question per thread.
How to write your question to maximize your chances to find a solution.
You've already seen STM32H755Zi-Q~How to share data between cores - which was answered here.
Have you studied that Application Note?
How to set up FreeRTOS debugging using STM32CubeIDE
https://www.youtube.com/watch?v=KTsrP28Gh6E
https://www.st.com/resource/en/user_manual/dm00629856.pdf#page=209
kavyammAuthorBest answer
Andrew Neil
Apr 25, 2025 7:19 AM UTC
