Lakshmi Lavanya
Dec 21, 2016 7:10 AM UTC
How to enter in to DFU mode at Run time
Posted on December 21, 2016 at 08:10
Hi all,
Can you please explain me how to enter in to DFU mode at run time. I don't have GPIO in my board.
So i did experiment with CDC class, when i get some command from my VCP port then i am entering in to DFU bootloader, but i need another way means using Dfuse tool i want to send the command i.e. 'Enter DFU mode/ HID detach'.
I tried with HID class alone but i am unable to get this button (Enter DFU mode/ HID detach).
How to enable this in Dfuse tool?
Can any body share any document or thread which can explain me about this.
#dfu
Oliver Beirne
Dec 21, 2016 7:00 PM UTC
Posted on December 21, 2016 at 20:00
Hi
Gamini.Lakshmi_Lavan
I have moved your post to
https://community.st.com/community/stm32-community/stm32-forum/activity
where product-related questions are asked. If you have any further questions post them here.
Oli
Jan 3, 2017 4:59 PM UTC
Posted on January 03, 2017 at 17:59
Dear
I recommend to check the
http://www.st.com/content/ccc/resource/technical/document/user_manual/3f/61/72/ff/c5/5a/4a/7b/CD001556pdf/files/CD001556pdf/jcr:content/translations/en.CD001556pdf
' Getting started with DfuSe USB device firmware upgrade STMicroelectronics extension' as mentioned about
Enter DFU mode/ HID detach'button
'Send Enter DFU mode command. Target will switch from Application to DFU mode or send a HID Detach if the device is a compatible HID device.' (whichis a HID class device providing the HID detach feature (USAGE_PAGE 0xFF00 and USAGE_DETACH 0x0055) in its report descriptor.)
Best Regards
Imen
Jan 13, 2017 5:31 PM UTC
Posted on January 13, 2017 at 18:31
Hi
Removethe comment code inDfuSeDemoDlg.cpp file (Line 347-368), this will active your HID devices enumeration.
Please try this update, then re-compile and let me know if the problem still there..
// Begin with HID devices // Commented in Version V3.0.3 and Keep it for customer usage if wanted.
ReleaseHIDMemory();
m_Enum.FindHidDevice(&m_HidDevices,&m_HidDevice_Counter);
FindMyHIDDevice();
for(i=0;i<int(m_HidDevice_Counter);i++)
PHID_DEVICE pWalk;
pWalk = m_HidDevices + m_Tab_Index[i];
if(HidD_GetProductString(pWalk->HidDevice, Product, sizeof(Product)))
for(j=0;j<160;j+=2)
Prod += Product[j];
else
Prod='(Unknown HID Device)';
String.Format('%s',Prod);
m_CtrlDFUDevices.AddString(String);
m_CtrlDevices.AddString(String);
Prod = '';
Imen
parsec
Jan 18, 2017 4:47 PM UTC
Posted on January 18, 2017 at 16:47
Hi, I'm having the same issue where 'Enter DFU mode/HID detach' button is always disabled.
I tried to recompile with the code above uncommented but my version of Visual Studio (2015) does not look have all the dependencies required. It upgradedthe project to the latest toolset when loading and now when trying to compile it generates 3000+ errors.
Could you please specify exact MS platform toolset and any additional dependencies that are required to compile this project?
Jan 19, 2017 10:21 AM UTC
Posted on January 19, 2017 at 10:21
Hello
Vazic.Relko
What exactly the error message did you get?
Imen
