Zainulabedeen
Nov 5, 2025 10:19 AM UTC
Generating SBOM for STM32 firmware projects
I want to generate an SBOM (Software Bill of Materials) for my STM32 firmware project, specifically targeting the STM32H733 microcontroller. I have tried searching for guides or examples of how others have done this for similar projects, but I haven’t been able to find any detailed resources. Any guidance or references on generating an SBOM for my firmware project would be greatly appreciated.
Dor_RHBest answer
Nov 11, 2025 10:01 AM UTC
Hello @Zainulabedeen,
The SBOM for STM32CubeH7 firmware package version 1.12.1, which supports the STM32H733 microcontroller, is available now on GitHub. You can access it here: https://github.com/STMicroelectronics/STM32CubeH7
I hope my answer has been helpful. When your question is resolved, please mark this topic as the solution. This will help others find the answer more quickly.
Thank you for your contribution.
Best regards,
Dor_RH
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Dor_RH
Andrew Neil
Nov 5, 2025 10:24 AM UTC
Zainulabedeen
Nov 5, 2025 10:30 AM UTC
I am currently looking for a solution that works now, as I believe the link you shared refers to a planned feature that isn’t yet implemented for STM32H7. I’m interested in learning what approaches others have used—either currently or in the past—to generate an SBOM for their STM32-based firmware projects ?
Dor_RHBest answer
Best regards,
Dor_RH
YahyaYozo
Mar 4, 2026 11:08 AM UTC
Hello @Dor_RH
I'm new to SBOM generation, and I need some help. In what way should I use the SBOM of the ST firmware package? Does it mean if I'm using Freertos in my project, I need to copy the freertos component from ST cube SBOM manually?
BR,
Yahya
Separate thread with the same question: Best practices for generating SBOM
Mar 5, 2026 9:00 AM UTC
Hello @YahyaYozo,
The SBOM provided with the STM32Cube firmware describes all the components in the package, including third‑party components included in the ST package (FreeRTOS, FatFS, lwIP, etc.).
For your own product, you should maintain your own SBOM that lists all components you actually use. If you are using FreeRTOS (or any other middleware) as delivered in the STM32Cube package, then:
  • Yes, FreeRTOS should appear as a component in your project SBOM.
  • You can reuse the information from ST’s SBOM (component name, version, license, origin) instead of recreating it.
  • Depending on your tooling, this can be done by importing/merging the ST SBOM, or by manually adding the relevant entries once.
In short: the ST SBOM is a reference that helps you accurately describe ST‑provided components; it does not replace your project SBOM.
Best regards,
Dor_RH
Oct 28, 2026 4:01 AM UTC
On the follow-up question about whether FreeRTOS has to be copied manually from ST's package SBOM: ST's sbom_cdx.json describes the whole Cube package, so you'd end up listing components your firmware may not even use.
I've been using an open-source tool I wrote that generates the project SBOM directly from your source tree: https://github.com/chen-embedded/fwsbom
pip install fwsbom
python -m fwsbom . --map Debug/yourproject.map --linked-only -o sbom.cdx.json
It reads the FreeRTOS, HAL, CMSIS, USB library and other versions from the vendored sources, picks up the Cube package version from the .ioc file, and with --map uses the linker map so only components actually linked into the image are listed. The output is CycloneDX with CPEs that Grype can match against NVD.
