Jul 17, 2025 7:15 AM UTC
Error: "non constant or forward reference address expression for section"
Hi All ,
Am imported a example project in  stm32cube and i tried to build am getting error as
Description Resource Path Location Type
non constant or forward reference address expression for section .ARM.extab LTDC_Paint line 90, external location: c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_1.5.0.202011040924\tools\arm-none-eabi\bin\ld.exe:D:\stm32_projects\exp1\LTDC_Paint\STM32CubeIDE\STM32H750XBHX_FLASH.ld C/C++ Problem
can u please provide the solution.
thankyou,
regards
shiva chary
Andrew Neil
Jul 17, 2025 7:21 AM UTC
What project ? For what board ?
Please describe what you actually did.
Did you make any changes?
How to write your question to maximize your chances to find a solution
KDJEM.1
Jul 18, 2025 8:34 AM UTC
Hello @shiva_chary ;
Could you please referring to UM2609 section 2.1.3 Importing existing project and following the steps to open the example.
I hope this help you.
Thank you.
Kaouthar
Andrew Neil
Jul 18, 2025 8:42 AM UTC
@shiva_chary wrote:
c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools...
Are you really using CubeIDE v1.6.0 ?
That's really old - current version is 1.19.0 !
https://community.st.com/t5/stm32cubeide-mcus/stm32cubeide-1-19-0-released/td-p/819568
Nov 8, 2025 9:03 PM UTC
I was also getting the same error. But when I changed the toolchain version from 10.3 -> 13.3 , it worked.
@shiva_chary
Seems like warning given in the guide is no more relevant.
Section 5: build the firmware
https://wiki.st.com/stm32mpu/wiki/Getting_started/STM32MP1_boards/STM32MP157x-DK2/Develop_on_Arm%C2%AE_Cortex%C2%AE-M4/Modify,_rebuild_and_reload_a_firmware
