Aug 6, 2025 12:51 PM UTC
target not found
hi iam having nucleoh755 board, in that when i try to flash target is not connecting and when not connecting to cube programmer also, it showing perform discovery using debug authentication. how to do it. please find the image for the error shown. and MCU power supply all are ok.
regards,
srinath
Srinath_03Best answer
Aug 6, 2025 1:14 PM UTC
hi @Imen.DImen.D thanks for the response, my problem has solved, i dont know how, when connecting to cube programmer i have changed to power down mode and target has connected, and i have erased the chip, after that it is fine. working normally.
regards,
srinath
Aug 6, 2025 1:09 PM UTC
Srinath_03AuthorBest answer
regards,
srinath
Aug 6, 2025 1:23 PM UTC
Hi @Srinath_03 ,
Good to hear you made it work and thanks for sharing your progress on this.
Aug 6, 2025 1:36 PM UTC
hi @Imen.D  thanks,
but i want to know what makes the mcu to go in that mode, i dont know fault problem, and why target not found issue came. mcu power supply are ok only, other than that what can cause the mcu to go that mode.
regards,
srinath
