Nov 11, 2025 10:07 AM UTC
STM32U575(LQFP64 (10 x 10 mm) Schematic and Hardware guidance for new design
I am currently working on a new hardware design using the STM32U575VIT6 (LQFP64, 10 × 10 mm) microcontroller.
I would like to request:
  • Reference schematics and layout guidelines for STM32U575 in LQFP64 package
  • Recommended power supply and decoupling capacitor design
  • Crystal oscillator and reset circuit design guidelines
  • Any available design checklists or application notes
My design overview:
  • ,low-power IoT sensor node
  • Peripheral interfaces planned: SPI, I²C, ADC, etc.
Kindly share any relevant schematics, PCB layout examples, and design documentation to ensure proper implementation.
Thank you very much for your assistance.
Harshith
Issamos
IssamosBest answer
Nov 12, 2025 8:54 AM UTC
There is not any evaluation board or official reference schematic based on the STM32U575VIT6 MCU. So, the best reference is the hardware design guide I’ve already mentioned.
Best Regards.
II
Issamos
Nov 11, 2025 11:21 AM UTC
Hello @HA2375-
I suggest you to refer to the AN5373 that will give you necessary informations for your design.
Best Regards.
II
HA2375-Author
Nov 12, 2025 8:50 AM UTC
Hi @Issamos
I have Referred ,i did not got the any schematic   of this STM32U575 in LQFP64 package Pls share the guidance schematic if you have .
thanks
Issamos
IssamosBest answer
Best Regards.
II
HA2375-Author
Nov 12, 2025 9:51 AM UTC
Am planning to Quad SPI, which port we can use, i cannot able to find the data sheet below listed pins can use
Controller -STM32U575VIT6 (LQFP64, 10 × 10 mm)
  • QSPI_CLK → PB2
  • QSPI_NCS → PB6
  • QSPI_IO0 → PD11
  • QSPI_IO1 → PD12
  • QSPI_IO2 → PE2
  • QSPI_IO3 → PE3
  • Pls suggest the pins details .
Issamos
Nov 12, 2025 11:03 AM UTC
Please select the answer of this post too since it is answered also.
Best Regards.
II
Andrew Neil
Nov 12, 2025 12:41 PM UTC
