Feb 13, 2025 12:47 PM UTC
ST-Link V2 Not Connecting to STM32F303RCT7
HI,
I am facing an issue where my ST-Link V2 is not detected in STM32CubeIDE while trying to connect to my STM32F303RCT7 board.
Below are the details:
:small_blue_diamond:**Issue Description:
** - ST-Link V2 is connected via USB, but it is not detected in STM32CubeIDE.
- ST-Link Utility/STM32CubeProgrammer also does not recognize the device.
- I have checked all connections (SWDIO, SWCLK, VCC, GND).
- The board is powered correctly (3.3V).
:small_blue_diamond:**Troubleshooting Steps Taken:
** :white_heavy_check_mark: Reinstalled ST-Link drivers
:white_heavy_check_mark:Tried different USB cables and ports
:white_heavy_check_mark:Updated ST-Link firmware
:white_heavy_check_mark:Checked connections with a multimeter
:small_blue_diamond:**System Details:**
- **MCU:** STM32F303RCT7 -
**Debugger:** ST-Link V2 -
**OS:** Windows-
**STM32CubeIDE
 Please guide me on how to resolve this issue.
        Thank you for your support.
STTwo-32
STTwo-32Best answer
Feb 21, 2025 5:25 AM UTC
with a Clone version, the connection may not work. So please make sure to use a genuine version.
Best Regards.
STTwo-32
Andrew Neil
Feb 13, 2025 12:55 PM UTC
Welcome to the forum.
Please see: How to write your question to maximize your chances to find a solution
@udhayakumar wrote:
my ST-Link V2 is not detected in STM32CubeIDE .
What, exactly, do you mean by that?
Show the error message(s) you get.
What CudeIDE version?
Is it a genuine ST-Link?
https://community.st.com/t5/stm32-mcus/how-to-recognize-a-genuine-st-link-v2-versus-a-cloned-one/ta-p/49471
Is the ST-Link detected by the PC?
https://community.st.com/t5/stm32-mcus/how-to-solve-debugger-connection-issues/tac-p/698105/highlight/true#M956
What board? Please give details
Feb 21, 2025 2:47 AM UTC
Hi bro,
i used clone version.
STTwo-32
Hello @udhayakumar and welcome to the ST Community.
Could you please share a picture of your ST-LINK V2. I think you are using a Clone version. More details available on the article How to recognize a genuine ST-LINK/V2 versus a clo... - STMicroelectronics Community.
Best Regards.
STTwo-32
Feb 21, 2025 2:46 AM UTC
HI bro,
yes,i used clone version.
Best Regards
udhayakumar
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
AScha.3
Feb 21, 2025 6:47 AM UTC
What ? st-link or target cpu ?
Try : CubeProgrammer, connect : normal + software reset . Then show, what its telling...
