Jul 21, 2025 9:18 AM UTC
Nucleo F439ZIT6: can't generate .ioc file
I am trying to work on STM32F439ZIT6 using its respective Nucleo board. I am not able to generate an ioc file even after installing the latest version 1.28.2 in STM32F4 series. Why is this happening and how can i resolve this issue?
avbST
Andrew Neil
Andrew NeilBest answer
Jul 21, 2025 9:34 AM UTC
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution for best results.
In particular, what tools (including version) are you using when trying to generate the .ioc file?
See this pinned post for a current known issue:
STM32CubeIDE STM32Cube project creation issue
Chaima_M
Jul 21, 2025 9:30 AM UTC
Hello @avbST,
I'll check and come back ASAP,
With best regards.
Andrew Neil
Andrew Neil
Jul 21, 2025 10:48 AM UTC
@avbST You've marked that as the solution - does that mean you were using one of the affected STM32CubeIDE versions?
avbSTAuthor
Jul 21, 2025 11:22 AM UTC
Yes, I was using an older version of STM32 Cube IDE. It is working as expected after installing the latest 1.19.0 version.
Jul 22, 2025 12:07 AM UTC
Good morning
I had the same problem and I solved it by following this post
https://community.st.com/t5/stm32cubeide-mcus/stm32cubeide-stm32cube-project-creation-issue/td-p/823125
If it helps
Sincerely
Pascal
Google translate:
Good morning
If it helps
Sincerely
Pascal
