NUCLEO-C562RE getting started
Hello All,
I have the NUCLEO-C562RE board and I wanted to get started with it. But I am lost and not able to find any documentation related to architecture manual or user manual. I am new to ST boards, previously I used Aurix TC375. Has someone here in the community used this board or similar one and know how to work around it? It would be really helpful.
Andrew Neil
Andrew NeilBest answer
@thetallnomad wrote:
Is there any specific version of CubeMX to be installed?
The C5 is a new family - it uses the new CubeMX2.
But it seems that's not available yet.
See also: STM32CubeMX2.,
Thanks for the documents.
I wanted to create a project in CubeMX and I dont see this STM32C5 series board options. I couldn't find it in MCU selector or board selector option. I could only see STM32C0.
Is there any specific version of CubeMX to be installed? I want the libraries and drivers for this board to write any application code or use FreeRTOS on it.
What I couldnt find from the above links you shared is the architecture manual. I wanted to know the address range of peripherals to write my own drivers or low-level APIs.
Any inputs here would be greatly appreciated.
Andrew Neil
LCE
Principal III
So there's no examples / CubeMX support out there yet?
If not, when can we expect that?
LCE
Principal III
You should find this in the Reference Manual and datasheet, follow the link TDK gave you before:
> The Reference Manual tells how the chip operates at a register level:
> https://www.st.com/en/microcontrollers-microprocessors/stm32c562re.html#documentation
Andrew Neil
Amel NASRI
Keep an eye to the list of articles with label STM32CubeMX2. You can subscribe to get notification about any new article there.
-Amel
mƎALLEm
STM32CubeC5 package is now available here for download.
And CubeMx2 is available here for download:
