Mar 12, 2024 8:51 AM UTC
Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
While trying to disable TZEN on a NUCLEO-WBA52CG boar after running the GPIO_IOToggle_TrustZone Example an both LEDs working as expected i encountered the error Error: ST-LINK error (DEV_TARGET_NOT_HALTED)
after switching from RP Level 1 to RP Level 0 and deactivating the TZEN Option bit
STTwo-32
STTwo-32Best answer
Mar 12, 2024 9:12 AM UTC
Hello @Isko
I suggest you take a look at this post. It should be helpful.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Hello @Isko
Best Regards.
STTwo-32
IskoAuthor
Mar 12, 2024 9:34 AM UTC
Hello @STTwo-32
can you explain to me how the process works and what exactly i nee to do
regards
Isko
STTwo-32
Mar 12, 2024 10:04 AM UTC
I suggest you take a look at the part 3.7 of the DS14127 and the RM0493. They should be helpful.
Best regards.
STTwo-32
