NFC03A1 writer and format example fro RPi4
pls suggest a example for reader/writer/formatter for NFC03A1
are there any writer example code for RPi similar to poller example ?
https://community.st.com/t5/st25-nfc-rfid-tags-and-readers/x-cube-nfc3-for-stm32cube/td-p/591339
i didnot find the source for the same..
i did notice X-CUBE-NFC3 , Ver 2.1.0 is available
https://www.st.com/en/embedded-software/x-cube-nfc3.html
Brian TIDAL
Brian TIDALBest answer
as of today, Linux demos for Raspberry Pi have been officially released only for ST25R3911B and for ST25R3916 NFC reader devices. An unofficial package for ST25R95 can be found in Solved: CR95HF - Linux RFAL demo - STMicroelectronics Community.
Regarding NDEF vs. raw proprietary data, NDEF has the advantage of being a standard format.
Rgds
BT
Brian TIDAL
which tag technology do you plan to use : T2T, T3T, T4T or T5T? Do you plan to write NDEF formatted message or raw proprietary data?
Rgds
BT
venukrishAuthor
Sorry for the delayed response Brian... i was OOO.
we will be using T2T and T5T (14443A and 15693 tags).
for now we will go with NDEF formatted messages.. i am not sure of raw proprietary data
do you see any advantages between them ?
Brian TIDAL
Rgds
BT
