AlbertCJohn
I have downloaded the iOS source code from https://www.st.com/en/embedded-software/stsw-st25ios001.html?icmp=tt12997_gl_****_oct2019 Part Number: STSW-ST25IOS002 But when I am compiling the code, I am facing compilation issue in the source code.
can anyone can help you in this regard?
    victor laraison
    victor laraisonBest answer
    Hi Jneig,
    The writemultipleblock commands has been added in the iOS14 beta release. We have started its integration into the iOS NFC Tap app, but we must wait the iOS14 official release in mid-september before delivering next version.
    So, I strongly suggest you to move on iOS14 for your tests...
    hope it clarifies.
    victor laraison
    ​hi Albert,
    Please, could you tell me what kind of comppilation issue you got ?
    thx and br,
    Vincent
    AlbertCJohn
    Thank for the reply Vincent
    Here is the issue I am facing
    'J2ObjC_header.h' file not found
    Failed to emit precompiled header '/Users/John/Library/Developer/Xcode/DerivedData/NFCTap_-ggvryqjowqjltpagmttuegrowgsc/Build/Intermediates.noindex/PrecompiledHeaders/ST25NFCApp-Bridging-Header-swift_WLJ36XJEPXM5-clang_1GHA8UW4ZC3V7.pch' for bridging header .
    AlbertCJohn
    Screenshot of the issue
    victor laraison
    hi Albert,
    The iOS NFC Tap uses the J2OBJC tool for translating Java into ObjC langage.
    So, you must download then install the j2objc into your environement.
    Download j2objc from https://github.com/google/j2objc/releases
    Go to the project setting of iOS NFC tap, then change J2OBJC_HOME environement variable.
    hope it helps.
    Thx and br,
    AlbertCJohn
    Thanks for your reply, I will check and keep you updated. Thanks Again for your support
    AlbertCJohn
    Hi Vincent, I am facing this error
    AlbertCJohn
    Attached Screenshot for reference
    AlbertCJohn
    We couldn't change the team from Unknown Name (9L4QA9SNQK) and we are blocked in compiling the build to iPhone 11
    victor laraison
    hi albert,
    You have to create your own provisioing profile from your Apple developer account.
    Here, you try to use mine, it is not the right one for you.
    Hope it clarifies.
    Br
    AlbertCJohn
    Thanks fixed the issue.
    we are hitting another compilation issue:
    'openssl/opensslv.h' file not found
