william jones
Jul 9, 2018 3:00 PM UTC
transistor ST32d/127 p5one can anybody help
Posted on July 09, 2018 at 17:00
ithey are from a heat zink on a 24v dc to dc motor control unit made in 2002 by sevcon model mos90b there are 2rows of 6 on the neg 6 input and 6 ouput  hi i have found a matching number stp50ne10
AvaTar
Senior III
Jul 10, 2018 10:44 AM UTC
Posted on July 10, 2018 at 12:44
ithey are from a heat zink...
I guess this is supposed to mean they are mounted on a heat sink.
Could you put a photo of the transistors in (with the type designation readable) in here ?
With the proper name, you could do a search for the datasheet yourself.
william jones
Jul 11, 2018 12:17 PM UTC
Posted on July 11, 2018 at 14:17
0690X00000604etQAA.jpgi have now posted the transistor
AvaTar
Senior III
Jul 11, 2018 3:02 PM UTC
Posted on July 11, 2018 at 15:02
Don't know this part, and I can't find anything. Perhaps it's a dual-diode ?
I would suggest to post your question to the 'Power Mangement and Motor Control' forum here :
https://community.st.com/community/power-management-and-motor-control
I expect better chances there.
Brian Kling
Senior
Jul 13, 2018 6:19 AM UTC
Posted on July 13, 2018 at 06:19
I will move it there.
Peter Fournier
Jul 13, 2018 12:49 PM UTC
Posted on July 13, 2018 at 14:49
I did a google search '32D127 transistor' and it came up with a TIP127 form monarch, newark # 3c0638.
The photo on the data sheet has the markings blacked out, but maybe Monarch can help you confirm it is the replacment
AvaTar
Senior III
Jul 14, 2018 11:06 AM UTC
Posted on July 14, 2018 at 11:06
Not sure if this is equivalent.
There are several transistors built in a TO220 package, with 127 as part of the type code.
The '32D' seems not to fit ST's naming scheme.
You can try to measure the resistance values between the terminals, which should give you an idea if it's a BJT, a MOSFET, a diode, or fried junk.
