Visitor
STM32C542RCT6 and TMP102 SparkFun
Hello Dear Community:
I am facing the following issue. I generated the project from Cube32MX for STM32C542RCT6.
I modified the following lines seems that a bug is present in the AF aka alternate functions.
* @file : mx_i2c1.c
* @brief : I2C1 Peripheral initialization
HAL_I2C_EnableAnalogFilter(&hI2C1);
/* ### I2C1 GPIO Configuration ########################### */
/* GPIO Clocks activation */
HAL_RCC_GPIOB_EnableClock();
hal_gpio_config_t gpio_config;
[GPIO Pin] ------> [Signal Name]
PB8 ------> I2C1_SCL
PB9 ------> I2C1_SDA
gpio_config.mode = HAL_GPIO_MODE_ALTERNATE;
gpio_config.output_type = HAL_GPIO_OUTPUT_OPENDRAIN;
gpio_config.pull = HAL_GPIO_PULL_NO;
gpio_config.speed = HAL_GPIO_SPEED_FREQ_LOW;
gpio_config.alternate = HAL_GPIO_AF4_I2C1; => HERE IS THE MODIFICATION
HAL_GPIO_Init(HAL_GPIOB, HAL_GPIO_PIN_8 | HAL_GPIO_PIN_9, &gpio_config);
In the main:
* You can start your application code here
for (uint8_t addr = 0x08; addr < 0x78; addr++) {
if (HAL_I2C_MASTER_Transmit(hi2c1, addr << 1, NULL, 0, 10) == HAL_OK) {
printf("Device found at 0x%02X\r\n", addr);
while (1) {
// Tell TMP102 that we want to read from the temperature register
buf[0] = REG_TEMP;
ret = HAL_I2C_MASTER_Transmit(hi2c1, 0x48, buf, 1, HAL_MAX_DELAY);
if ( ret != HAL_OK ) {
strcpy((char*)buf, "Error Tx\r\n");
} else {
// Read 2 bytes from the temperature register
ret = HAL_I2C_MASTER_Receive(hi2c1, 0x48, buf, 2, HAL_MAX_DELAY);
strcpy((char*)buf, "Error Rx\r\n");
} else {
//Combine the bytes
val = ((int16_t)buf[0] << 4) | (buf[1] >> 4);
// Convert to 2's complement, since temperature can be negative
if ( val > 0x7FF ) {
val |= 0xF000;
// Convert to float temperature value (Celsius)
temp_c = val * 0.0625;
// Convert temperature to decimal format
temp_c *= 100;
sprintf((char*)buf,
"%u.%u C\r\n",
((unsigned int)temp_c / 100),
((unsigned int)temp_c % 100));
// Send out buffer (temperature or error message)
HAL_UART_Transmit(huart2, buf, strlen((char*)buf), HAL_MAX_DELAY);
// Wait
HAL_Delay(500);
1) I cannot see Device found at
2) It returns HAL_ERROR
Debugging I can see:
* @file stm32c5xx_hal_i2c.c
* @brief I2C HAL module driver.
hal_status = I2C_WaitOnFlagUntilTimeout(hi2c, LL_I2C_ISR_BUSY, 1U, I2C_DEFAULT_TIMEOUT_MS, tick_start);
if (hal_status == HAL_OK) => this is OK
And here is HAL_ERROR:
while (hi2c->xfer_count > 0U) { hal_status = I2C_WaitOnTXISFlagUntilTimeout(hi2c, timeout_ms, tick_start); if (hal_status == HAL_OK)
Thanks for your support.
Manuel.
Manuel5Best answer
Visitor
After rechecking the Data Sheet and User Manual I’ve found the issue:
I created a brand new MCU in STM32CubeMX2:
/* [GPIO Pin] ------> [Signal Name]
PB6 ------> I2C1_SCL
PB7 ------> I2C1_SDA
gpio_config.alternate = HAL_GPIO_AF_4;
HAL_GPIO_Init(HAL_GPIOB, HAL_GPIO_PIN_6 | HAL_GPIO_PIN_7, &gpio_config);
The generation must match:
Table 15. ARDUINO® Digital[15:8] connector (CN5) pinout
Depicted in:
UM3615
STM32C5 Nucleo-64 board (MB2213)
The device is found and the temperature is being sent back.
Manu.
What was this line pre-modification?
Can you include your IOC file?
Did modifying that line fix the problem? It’s unclear from the post if the issue is still present.
Manuel5Author
Visitor
Hello.
Before modification:
* @file : mx_i2c1.c
Regards.
Manu.
Manuel5Author
Visitor
That modification did not work.
Still fails with HAL_ERROR so as mentioned in:
There is no bug here. Why do you think there is? Look at the source:
#define HAL_GPIO_AF4_I2C1                HAL_GPIO_AF_4 /*!< I2C1 Alternate Function mapping        */
So probably the sensor is not powered or hooked up correctly. Use HAL_I2C_IsDeviceReady and ensure it returns HAL_OK before using any other I2C function.
Manuel5Author
Visitor
  • According to the documentation the TMP102 by  SparkFun does not need any external pull up.
  • The multimeter shows 3.33v stable for 1.4v-3.6v, SDA, SCL and ALT on the sensor
  • The attached image show the debugger after evaluating: ret = HAL_I2C_MASTER_PollForSlaveReady(hi2c1, 0x48, 10000);
  • Using TMP102_ADDR = 0x48 << 1; // Use 8-bit address gives the same HAL_ERROR
Manuel5Author
Visitor
Wiring images also shared through photos.
Manuel5AuthorBest answer
Visitor
Depicted in:
UM3615
Manu.
Andrew Neil
If that’s resolved your issue, please mark it as the solution
For future reference when posting code, please see:
Also:
So you were just using the wrong pins? Yeah, I don’t see how anyone could have caught that with the lack of information given in the OP.
Andrew Neil
Indeed.
​@Manuel5 - this is why it’s important that you provide a schematic!
https://community.st.com/community%2Dguidelines%2D160/how%2Dto%2Dwrite%2Dyour%2Dquestion%2Dto%2Dmaximize%2Dyour%2Dchances%2Dto%2Dfind%2Da%2Dsolution%2D118622
