Senior
Apr 18, 2025 12:03 PM UTC
Going in HardFault
I plan to transmit stream of approx 10k characters by uart every second. For that purpose, I have definer global char array of 10.5k length. After working for few second, the MCU goes in HardFault.
I tried with array of 1000 bytes only, it works fine. But as I increased to 10k bytes array, problem start coming.
Should I change stack sizes in linker file. ? please suggest and where to change.
TDKBest answer
Apr 18, 2025 1:56 PM UTC
Global arrays don't use the stack.
Possibly a write out of bounds causing issues. Definitely a bug in the code somewhere. I suggesting finding and fixing the bug.
MM..1
Apr 18, 2025 12:15 PM UTC
show code
TDKBest answer
Andrew Neil
Apr 18, 2025 3:01 PM UTC
So, with 10 bits/character, about 100kbit/s.
Certainly, the UART hardware can cope with that.
But can your code keep up?
So narrow it down some more - try sizes between 1k and 10k
So you need to find what's causing the Hard Fault:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/tac-p/708193/highlight/true#M51
Nico3Author
Senior
Apr 18, 2025 3:13 PM UTC
I found the fault. Increased the size of array and not crashing anymore.
Andrew Neil
Apr 18, 2025 4:17 PM UTC
@Nico3 wrote:
I found the fault.
Good to hear - so what, exactly, was the problem?
please mark that post as the solution.
See: https://community.st.com/t5/community-guidelines/help-others-to-solve-their-issues/ta-p/575256
@Nico3 wrote:
But i see another problem now. .
Please start a new thread for that.
Nico3Author
Senior
Apr 18, 2025 4:23 PM UTC
Hi andrew,
The array length was insufficient...
