File missing in the example LoRa module SX1262 for LoRaWAN
  • September 2, 2025
  • 3 replies
  • 624 views
hello... I am using custom board with STM32F103C8T6 with Semtech LoRa module SX1262 for LoRaWAN architecture. Facing lot of issues like files missing. We are using the files from Github link
Best answer by mƎALLEm
I don't think ST provided that solution.
You may look for a working solution on the internet:
Related threads posted in this community:
https://community.st.com/t5/stm32-mcus-embedded-software/lora-sx1262-integration/td-p/594370
https://community.st.com/t5/stm32-mcus-wireless/hard-fault-occurs-when-using-sx1262-lora-module-with/td-p/684134
PS: files missing after downloading a folder from github could be because you didn't use --recursrive option when you cloned the github package. So please read this article: Downloading STM32Cube packages from GitHub correctly
mƎALLEm
Hello @Antony0375 and welcome to the ST community.
Which github link? was it created by ST?
If not this is not the correct place to ask that question but to the owner of that github.
can you pls share the ST Github link for STM32F103C8T6 + sx1262 ,our Board
is customized for 23 IO pins.
mƎALLEm
mƎALLEmBest answer
