KSamn.1
Teseo-LIV3F : NMEA messages
I am facing problem Teseo-LIV3F is not sending out any NMEA messages and also not accept any commands. Anyone know Why? and How to set back to "Factory Setting" ?
    Javier1
    Principal
    December 19, 2022
    what if the Teseo is working but your uart config is wrong?
    If i were you i would stick an oscillocope/logic analizer on those RX/TX traces
    hit me up in https://www.linkedin.com/in/javiermuñoz/
    KSamn.1
    KSamn.1Author
    I sticked an oscillocope/logic on Pin2(UART_TX) but I could not see any signal coming out.
    Before I sent command to change uart baurate to 38400 i received NMEA messages from Pin2.
    Do you have any idea what happpened with uart config?
    The command I send to change baurate is: PSTMCFGPORT,0,0,1,38400
    Javier1
    Principal
    December 20, 2022
