mnicolae
May 20, 2026 10:06 UTC
Starter Package for NTM88 and MKW01
Hi, I am working on a TPMS project and I have migrated from FXTH to NTM88. With the FXTH I was using the MKW01 board for RF communication, on the NTM88 side, to use the same RF board I need the Starter Package for NTM88 and MKW01. The link can be found on NXP website but doesn't work. I have been advised to get in touch with you as the NXP MEMS sensor products have been transitioned to you since February 2026.
 I have also search on ST website but with no luck. Would it be possible to advice how can I get hold of the info from the NTM88 and MKW01 package?
  Regards,
Mihnea
Andrew Neil
May 20, 2026 10:13 UTC
Yes, I noticed that.
I've not seen any other activity in this Community yet, so you might be better contacting ST Support direct:
https://ols.st.com/s/
mnicolae
mnicolaeAuthor
May 20, 2026 10:17 UTC
Hi Andrew, same here, nothing helpful in this community yet, but thanks, I will contact ST Support directly.
Much appreciated
Andrew Neil
May 20, 2026 10:21 UTC
Please update on how you get on; hopefully you'll be able to mark that as the solution - in due course ...
