LSM6DSO Pedometer
  • August 12, 2024
  • 3 replies
  • 1188 views
Hi BenG142, I'm trying to develop a pedometer application using the LSM6DSOX sensor, but I haven't been successful. Could you share your project files with me? I'd like to know which registers you used.
Best answer by BenG142
Hi @MasCreyt21 ,
Without more information on where you've been unsuccessful, I will try to explain all steps.
So, assuming you've had positive communications with the IC (read/write registers, etc):
1. Start by setting up the Performance/ Power Mode you want:
 case XL_Power_Mode_ODR::Mode_High_Performance_6_66_kHz:
 WriteRegisterBitRange(LSM6DSOX_CTRL1_XL, 7, 4, 0b1010 );
 WriteRegisterBit ( LSM6DSOX_CTRL5_C, 7, false ); //XL_ULP_Enable
 WriteRegisterBit ( LSM6DSOX_CTRL6_C, 4, false ); //XL_HM_Mode
 break;
2. Set up FIFO:
void LSM6DSOX_::setFifo_Steps(){
 WriteRegister ( LSM6DSOX_FUNC_CFG_ACCESS, 0x80 ); //Open Embedded Functions
 WriteRegisterBit( LSM6DSOX_EMB_FUNC_EN_A, 3, true ); //Enable Pedometer sensor in Adv Func
 WriteRegister ( LSM6DSOX_EMB_FUNC_EN_B, 0x10); //Enable false positive rejection
 WriteRegisterBit( LSM6DSOX_EMB_FUNC_FIFO_CFG, 6, true ); //Enable Step Counter Batching
 WriteRegister ( LSM6DSOX_FUNC_CFG_ACCESS, 0x00); //Close Embedded Functions
 WriteRegisterBitRange( LSM6DSOX_FIFO_CTRL4, 2, 0, 0b001 ); //set FIFO Mode
3. Read FIFO Registers:
 uint8_t reg1 = LSM6DSOX.ReadRegister(LSM6DSOX_FIFO_STATUS1);
 Serial.print("FIFO Status 1: ");
 Serial.println( reg1 );
 uint8_t reg2 = LSM6DSOX.ReadRegister(LSM6DSOX_FIFO_STATUS2);
 Serial.print("FIFO Status 2: ");
 Serial.println( reg2 );
4.  Clear FIFO at the end:
void LSM6DSOX_::setFifo_Clear(){
 WriteRegisterBitRange( LSM6DSOX_FIFO_CTRL4, 2, 0, 0b000);
Sadly not able to share the project, but hopefully this helps.
Cheers,
Ben
Screenshot from the closed thread mentioned by @Andrew Neil (Credit to @Federica Bossi) :
Andrew Neil
@MasCreyt21 wrote:
Hi BenG142
@BenG142 's thread was closed over a year ago:
https://community.st.com/t5/mems-sensors/lsm6dso-fifo-pedometer/td-p/61470
So tell us what you did, and why you consider that "unsuccessful"
Did you follow the steps give by Ben and @Federica Bossi in the previous thread?
Please see the Posting Tips:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
BenG142
BenG142Best answer
Hi @MasCreyt21 ,
 break;
2. Set up FIFO:
Cheers,
Ben
@BenG142
Thank you for your help, BenG142. Thanks to you, I solved my problem, and the LSM6DSOX is working as I wanted.
