Smalik
LIS2DH12TR- Not working on 2.9V and above voltages
  • October 20, 2022
  • 22 replies
  • 4373 views
I am using LIS2DH12TR through SPI but I am not able to operate it on greater than 2.8V. On greater than 2.8V I am not able to read the device ID. But according to the datasheet, it is able to operate up to 3.6 V. SO how can I use this ic greater than 2.8V?
Any help would be appreciable
Thanks and Regards
Sarthak Malik
    Eleon BORLINI
    Hi Sarthak Malik @Smalik​ ,
    Are you using the Vdd and VddIO together?
    -Eleon
    Smalik
    SmalikAuthor
    Hello Eleon @Eleon BORLINI​
    Sorry for the delayed response actually the Diwali holidays were going on that's why I am unable to reply.
    Yes, I am using the Vdd and VddIO together.
    Sarthak
    Smalik
    SmalikAuthor
    Hello @Eleon BORLINI​ ,
    I hope you are doing well.
    Can you please help me out in this case? I am waiting for your response.
    Sarthak
    Smalik
    SmalikAuthor
    I am waiting for the update. please help to use this IC on 2.9V to 3.3V.
    Sarthak Malik
    Eleon BORLINI
    sorry for the delay in my answer. The parts should have no issue in this sense, since we never encountered this kind of limitation and they are tested 100% at 3.6V. Which is precisely the condition you are operating? Is the application processor capable to read at that voltage? Could you try also to lower VddIO with respect to Vdd?
    -Eleon
    Smalik
    SmalikAuthor
    Hello Eleon BORLINI,
    Yes, the processor is capable to read the 3.6V and we have other sensors as well on the same board which is working on 3.3V. and we can not try to use lower VddIO because it is by default short by the Vdd in our board.
    Sarthak Malik
    Smalik
    SmalikAuthor
    Hello Eleon BORLINI @Eleon BORLINI​ ,
    I am waiting for your answer.
    Sarthak
    Eleon BORLINI
    Hi @Smalik​ ,
    you might try another part if this one is not working.
    -Eleon
    Smalik
    SmalikAuthor
    Helo Eleon @Eleon BORLINI​ ,
    Thanks for the update. Is there any problem related to this part? Because I have manufactured 100k boards by using this IC. Please provide me with the correct resolution.
    Sarthak Malik
    Eleon BORLINI
    due to the volume you are reporting, I just escalated the case to OLS so that you can get a broader support on this issue.
    -Eleon
