Mar 27, 2025 4:34 AM UTC
Issues with STPM34-EVAL Board.
Hello Team,
We have a STPM34-EVAL board and we are trying to interface 220V AC with it, Earlier the software worked well and were able to see all correct values, Now voltage seems to be messed up. Current detection is fine.
Will you be able to provide a defaults file that we can flash on EVAL board?
Also we are building our custom 3-Phase board with 2*STPM34's, Is there any detailed procedure for production flashing these parameters?
Regards,
Pavan.O
Peter BENSCH
Mar 31, 2025 8:21 AM UTC
The Community is not a technical support team, but a peer-to-peer forum (see Terms and Conditions, article 2 etc). As it is very likely that no community user will be able to help you, please ask your questions again to your local distributor or to the personal Online Support OLS.
Regards,
/Peter
