Jun 26, 2025 10:29 PM UTC
Writing an article on Knowledge base?
Hi guys,
i am an embedded firmware engineer, with a lot of projects on stm32 micro controllers, including the communication protocols, battery management systems , ultra wide band, and EV charging, i wanted to know if i can post or share my projects or libraries on stm32 knowledge base ?or it is restricted to some people ?if yes then how do i get access to posting knowledge base articles,?
Thankyou.
Andrew Neil
Andrew NeilBest answer
Jun 27, 2025 8:12 AM UTC
@Tesla DeLorean wrote:
You can post your own threads, they don't have to be questions. You get to pick titles, etc.
@Obaid_tanveer a tip if you do that:
Post it as a question, then post your article as a reply - and mark that as The Solution.
(the forum doesn't allow you to mark the initial post as a solution)
Jun 27, 2025 3:27 AM UTC
Perhaps formulate and post to Github, and discuss with ST forum managers.
Most are posted directly by ST Staff Engineers, not users. You can post your own threads, they don't have to be questions. You get to pick titles, etc.
Andrew Neil
mƎALLEm
Jun 27, 2025 8:19 AM UTC
The knowledge base articles are restricted to the ST employees and there is no plan to extend to ST community members for now. But for now and as stated by @Andrew Neil post a question and answer it with the solution you provide.
Laurids_PETERSEN
ST Community Manager
Jun 27, 2025 8:51 AM UTC
Hello @Obaid_tanveer,
Thank you for your interest in contributing to the knowledge base. We value the enthusiasm of our community members in sharing their projects, and I am happy to assist you with this process.
The knowledge base articles are primarily authored by ST employees, as others have mentioned. However, there have been exceptions. For example, the article Injecting and handling ECC errors in STM32H7 flash was created in collaboration with @20jmorrison based on their forum post.
If you already have a first draft, or a GitHub repo with a guided description/readme, feel free to send me a private message. I will coordinate with the relevant subject matter expert to verify the content. Please note that we have a standard template for articles, so adjustments may be required to align with that format.
Alternatively, you can share your projects in the product forums. This option also provides you with the flexibility, as @Tesla DeLorean mentioned, to write in a style that suits you best.
I look forward to hearing your feedback on this.
Best regards,
Laurids
Jun 27, 2025 9:46 AM UTC
Thankyou, I will reach you out with my first draft soon.
