Andrew Neil
May 20, 2024 10:44 AM UTC
'Top Solution Authors' avatars broken
Also broken in the '@' lookups:
Except, perhaps, Ascha.3:
Andrew Neil
Andrew NeilBest answer
May 21, 2024 9:41 AM UTC
Now working again:
STTwo-32's avatar:
https://community.st.com/t5/image/serverpage/avatar-name/modern/avatar-theme/candy/avatar-collection/architecture/avatar-display-size/message/version/2?xdesc=1.0
Peter's avatar:
https://community.st.com/t5/image/serverpage/image-id/49254i064C6BBB9E75D2B8/image-dimensions/40x40?v=v2
May 20, 2024 12:54 PM UTC
Seems to be fine here. Perhaps a caching or rendering issue? SHIFT+RELOAD ?
Perhaps blocking or optimization scripts?
Andrew Neil
May 20, 2024 1:03 PM UTC
That was on my usual Chrome browser, logged-in.
On Edge (which I very rarely use), logged-out, I still see the same.
May 20, 2024 4:12 PM UTC
Not discounting your observation, but might be indicative of distributed server, proxies, and caches used by ST over the globe.
The counts don't seem to be entirely consistent depending on where/when you look, probably things rolling on/off from the 30-day averages.
Chrome for me, varying versions, couple of different Comcast/Xfinity service points, Chicago region.
Andrew Neil
May 20, 2024 4:37 PM UTC
Andrew Neil
Andrew NeilAuthorBest answer
Lina_DABASINSKAITE
ST Community Manager
May 24, 2024 9:56 AM UTC
Hello @Andrew Neil ,
Thanks for reporting this! As these issues are device/user specific, it would be best if you could share with me the .HAR file of the browser once you experiencing this issue again.
The instruction how do it is here: ST community site often very slow / unusable - STMicroelectronics Community
Thanks,
Lina
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Andrew Neil
May 24, 2024 10:14 AM UTC
Thanks - I'll bookmark that for next time stuff like this happens ...
