waclawek.jan
Sometimes the editor magic does not happen
This is something I haven't seen in last couple of months, but appeared and happens relatively often since last week or two.
#updates_are_not_universally_good_thing
#unnecessary_javascriptoiding_is_a_bad_thing
February 13, 2024
Hi @waclawek.jan ,
Thanks for sharing your experience. I was able to replicate it and reported the issue.
Best,
Adam
waclawek.jan
Hi @unknown Adam,
In the last few days the problem got worse - I now have to reload a post several times, until the edit line's "magic" starts to "magic".
What now?
Can't the editor window simply be displayed unconditionally, without any "magic", like in normal fora?
March 6, 2024
Hi @waclawek.jan ,
Can you please try updating your browser to the latest version and clear the cache? Please let us know if it solved the problem as it did in our case.
Best,
Adam
waclawek.jan
Hi Adam @unknown ,
I've just cleared cache and site data because of a different thread, and then tried to answer one of the regular posts and look what just happened (or, more precisely, did not happen):
Win10, FF123.0.
March 18, 2024
Hi @waclawek.jan , @Andrew Neil , @Tesla DeLorean ,
Thank you for the additional information, which will be used to re-investigate this case.
Best,
Adam
Andrew Neil
I had it happen this morning.
Google Chrome Version 122.0.6261.111 (Official Build) (64-bit) on Win 11.
March 7, 2024
Still happening randomly, some times works, some times not. I can fill a whole line sometimes and it still doesn't fire up. Other times it does, but then have to be careful about it catching up to where I'm at.
I realize it's not working, and either abort, or finish my thought, and copy the line I've typed and go back to the top to hit Reply.
Some times Reply button's are laggy, and I have go deeper into the pane to get the cursor.
Using Google Chrome, several machines, and always within one or two versions of the most current release.
Honestly what I'd like to see is it just acts as a "lightweight" pane, without all the formatting clutter, so I can just type..
waclawek.jan
Hi @unknown ,
new data point: if the "magic" did not happen, clicking on "Reply" on any other post results in two editor panes to open.
Andrew Neil
This seems to have got much worse lately - it seems lately that "the editor magic" never happens on that 'Reply' button.
After using any other 'Reply' button in the thread, that one does seem to remember what it's supposed to do.
See also: https://community.st.com/t5/feedback-forum/st-website-getting-worse/td-p/657943
Andrew Neil
Actually, it seems that the yellow one is "dimmed":
It has let me click in the box, and the box border has gone bold - so it's recognised my click, and set the focus - but it doesn't present the composition window, and doesn't allow me to type anything. It doesn't even give a caret in the box.
But If I click on the blue 'Reply' button, I  get two composition windows!
First is the one for the blue reply button to the specific post; second is the one for the yellow button
EDIT
@waclawek.jan did mention the two-window thing earlier.
NXP seem to be using the same forum software. On there, they have a "quick reply" which, IIRC, doesn't present a full composition window - it's just a quick "type in the box".
Maybe this forum is trying to do that, but failing?
Lina_DABASINSKAITE
ST Community Manager
April 15, 2024
Hello all,
Thank you for your reports on this issue.
After investigation, it has been identified as a bug. I will update you once I have more information to share about the fix.
I am sorry for this inconvenience,
Lina
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Lina_DABASINSKAITE
March 18, 2025
Hello all,
This issue has been fixed. Let us know if you still face it on your end.
Thank you,
Lina
