waclawek.jan
Jan 5, 2024 7:36 AM UTC
Can't see breadcrumbs on main ST web
There's no forum to report bugs on main st.com site.
Breadcrumbs appear briefly when scrolling, but then they are overlapped by the "stuff" on top.
The "modern" webdesign is a disaster.
    Lina_DABASINSKAITE
    ST Community Manager
    Apr 5, 2024 12:38 PM UTC
    Hello @waclawek.jan ,
    Can you please check now? I got informed and the issue has been resolved.
    Thanks,
    Lina
    ​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
    Lina_DABASINSKAITE
    Jan 10, 2024 1:49 PM UTC
    Hi @waclawek.jan ,
    Thanks for bringing this is up. This seems not a bug but a design solution - the breadcrumbs are not fixed on top when scrolling.
    AScha.3
    Jan 15, 2024 1:08 PM UTC
    Hey, @waclawek.jan ,
    now you know :
    waclawek.jan
    Jan 10, 2024 2:03 PM UTC
    Hi @Lina_DABASINSKAITE ,
    You seem to have misunderstood me.
    The breadcrumbs are *not* visible in the static case, that's how I made the above screenshot.
    They are visible only briefly during scrolling, and when scrolling stops, the top stuff overlaps them.
    Lina_DABASINSKAITE
    Jan 12, 2024 1:52 PM UTC
    Hi @waclawek.jan ,
    I see, thanks for clarifying. Please share the browsers and its' version you use so we can investigate.
    I checked myself on Chrome, Firefox, Edge - was everything fine.
    Thanks,
    Lina
    waclawek.jan
    Jan 12, 2024 3:43 PM UTC
    Lina_DABASINSKAITE
    Jan 15, 2024 12:23 PM UTC
    Thanks, @waclawek.jan!
    I will pass it to a responsible team to further look into it.
    Could you also try opening it on other browsers and see if the issue replicates on your end?
    Thanks,
    Lina
    waclawek.jan
    Jan 15, 2024 1:16 PM UTC
    I don't use other browser on PC.
    waclawek.jan
    Jan 16, 2024 10:40 AM UTC
    This is a laptop with HD (1920x1080) display, but its physical dimensions are too small, so I use the 125% zoom (which btw. is the default and "recommended" by Windows itself):
    As an experiment, I've set it to 100% and the breadcrumbs became not been overlapped; but that's not a practically usable setup for this hardware, of course.
    I hope this helps to find the bug.
    Lina_DABASINSKAITE
    Jan 17, 2024 1:32 PM UTC
    Hello, @waclawek.jan ,
    Our team got back and found out exactly the same - the breadcrumbs position changes when screen scale is more than 100%. They are working on the fix.
    Thanks a lot for your inputs here.
    BR,
    Lina
    Lina_DABASINSKAITE
    Mar 7, 2024 12:29 PM UTC
    Hi @waclawek.jan ,
    The fix has been implemented. Please check if it is OK on you end too.
    Thanks,
    Lina
    waclawek.jan
    Mar 7, 2024 3:03 PM UTC
    No, it's not OK:
    This is after clearing all site data and cache.
    W10, FF123.0.
    Lina_DABASINSKAITE
    Thanks,
    Lina
    waclawek.jan
    Apr 5, 2024 7:10 PM UTC
    It appears to work now, at least on the laptop where I noticed it initially.
    Thanks,
