Lina_DABASINSKAITE
ST Community Manager
Apr 21, 2026 9:56 AM UTC
Hi @Andrew Neil,
The troubleshooting team got back confirming issue was caused due to the server error that day which is now fixed. The feature should work as expected.
Let me know if it works well on your side.
Thanks,
Lina
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Lina_DABASINSKAITE
Apr 1, 2026 12:25 PM UTC
Hi @isikli , @Andrew Neil ,
Thank you for your patience. The fix is expected to be available tomorrow during EMEA business hours.
Let us know if you still have issues then.
Thank you,
Lina
Andrew Neil
Apr 1, 2026 1:30 PM UTC
We'll look forward to it!
It did seem to have been working OK for a couple of weeks - just started seeing the errors again yesterday
Andrew Neil
Apr 1, 2026 4:44 PM UTC
It just worked on this knowledgebase article , but fails on posts in this user thread .
Andrew Neil
Apr 2, 2026 10:44 AM UTC
Must be working for some - but not me & @unsigned_char_array,  (at least):
unsigned_char_array
Lead III
Apr 2, 2026 11:13 AM UTC
Now it works for me again.
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
Andrew Neil
Apr 2, 2026 11:44 AM UTC
me too (for now...)
This feature is up & down like a yo-yo !
Lina_DABASINSKAITE
Apr 9, 2026 9:00 AM UTC
Hi all,
The issue has been fixed, and kudo button should work as expected. Please check on your end and let me know if it works or you still face issues.
Thanks,
Lina
Andrew Neil
Apr 9, 2026 9:30 AM UTC
It is working at the moment ...
Also pasting images ... ?
Lina_DABASINSKAITE
Apr 9, 2026 9:42 AM UTC
Indeed! But please give it a try with some more attempts to test.
Andrew Neil
Apr 13, 2026 2:05 PM UTC
@Lina_DABASINSKAITE - I Unmarked the solution, as it's playing-up again this afternoon (was OK in the morning).
It's now intermittent: the red "unable to complete the action" banner sometimes appears, but then trying again immediately generally works.
I think I saw it once when the error popped up briefly, then the Kudos count did change!
Lina_DABASINSKAITE
Apr 14, 2026 1:09 PM UTC
Hi @Andrew Neil , thanks for letting me know. I have informed the reponible team about it.
When it happens, please grab a HAR file of the page with an error.
Thanks,
Lina
