Lina_DABASINSKAITE
ST Community Manager
Apr 21, 2026 9:56 AM UTC
Hi @Andrew Neil,
The troubleshooting team got back confirming issue was caused due to the server error that day which is now fixed. The feature should work as expected.
Let me know if it works well on your side.
Thanks,
Lina
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
waclawek.jan
Mar 12, 2026 2:16 PM UTC
I've experienced this in the morning (at a different post), but it appears to have healed itself since then :)
Andrew Neil
Mar 12, 2026 2:23 PM UTC
I just managed to Kudo your post.
So I checked others - they are also working now.
waclawek.jan
Mar 12, 2026 2:57 PM UTC
I spoke too soon - I am unable to kudo *your* above post!
Please un-mark my post (even if it's hard to find :) ).
Andrew Neil
Mar 12, 2026 3:04 PM UTC
I could Kudo your latest post, but have unmarked the solution anyhow - for now ...
Laurids_PETERSEN
Mar 12, 2026 3:17 PM UTC
Hi @Andrew Neil,
Thanks for reporting this. I'm sorry about the inconvenience.
I faced the same issue with that specific reply. I have captured the needed log files for support to investigate further.
I'll report back once I have any news.
Pavel A.
Mar 13, 2026 5:12 AM UTC
Kudos seems working for me now.
unsigned_char_array
Lead III
Mar 13, 2026 9:58 AM UTC
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
Andrew Neil
Mar 13, 2026 11:24 AM UTC
And now it's stopped working again for me.
Including trying to UN-Kudo @unsigned_char_array's post above (not any reflection on the content - purely as a test of the Kudo functionality!)
unsigned_char_array
Lead III
Mar 13, 2026 1:17 PM UTC
It works again for me.
Lina_DABASINSKAITE
Mar 13, 2026 1:23 PM UTC
Thank you for reporting this behavior. The technical team has identified the issue and is working to resolve it. You will be notified once the issue is resolved.
Regards,
Lina
Andrew Neil
Mar 14, 2026 9:38 AM UTC
And this morning it's broken again.
Andrew Neil
Apr 1, 2026 9:56 AM UTC
It's happening again.
isikli
Apr 1, 2026 12:13 PM UTC
