Lina_DABASINSKAITE
ST Community Manager
Dec 3, 2024 11:43 AM UTC
Hi @Andrew Neil ,
Thanks for sharing this! Seems that the respective member has simply inserted the title incorrectly over there. There is no issue with the title section. If you notice similar posts, simple report them using "Report Inappropriate Content" option and we will take it from there.
Regarding:
@Andrew Neil wrote:
PS:
Interestingly, a search for "&quot" seems to interpret that as quotation marks:
I will report this to check if this is expected behavior.
Let me know if you will notice anything else. Thanks!
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Andrew Neil
Dec 3, 2024 1:17 PM UTC
It seems highly unlikely that @JPabl.1 would manually type """ like that - twice - so looks like something the forum has misinterpreted?
Lina_DABASINSKAITE
Dec 4, 2024 9:49 AM UTC
Hello @JPabl.1,
Could you share the process of typing/copying text in your titles, so we can check if there’s something wrong with this feature?
I did the test with copying and typing simple quotes ("") in the title and saw no issue so far.
Thanks!
Andrew Neil
Jan 6, 2025 10:47 AM UTC
Another one today:
https://community.st.com/t5/stm32-mcus-motor-control/missing-library-amp-quot-trajctrl-h-amp-quot-when-creating/td-p/758476
@phamtutailtvm - can you describe how that happened?
(I've edited it now)
Jan 7, 2025 2:03 AM UTC
I need a header file named "TrajCtrl.h". I want to build an EtherCAT project on the STEVAL-ETH001V1 kit. But I can't find this file in the vendor's firmware.z6204073350232_ce8e51cec81eeea7516d2f92a7d59eaf.jpg
Andrew Neil
Jan 7, 2025 10:13 AM UTC
@phamtutailtvm I'm asking here how you ended up with those raw HTML tags in your post title:
For discussion of the actual issue with your code, stick to the main thread.
Andrew Neil
Jan 8, 2025 10:02 AM UTC
And another today:
https://community.st.com/t5/feedback-forum/stm32f103cbtba-bluepill-board-amp-lt-signal-handler-called-amp/td-p/759525
@ronaksm - how did you enter the title of that post? Was it a copy & paste from somewhere? If so, where?
(This is just about the issue in the post title - keep discussions about the actual problem in the original thread)
