Versions of stm32 ecosystem for NUCLEO-N657X0-Q
Hello ST community!
Currently i'm working on a project based on the stm32 NUCLEO-N657X0-Q which should be delivered very soon .
I followed this article https://community.st.com/t5/stm32-mcus/how-to-build-an-ai-application-from-scratch-on-the-nucleo-n657x0/ta-p/828502 step by step with the same versions of software mentioned but without any results .
I tried using X-Cube AI and the new tool Stm32Cube AI studio but i ended up with a lot of confusion and errors .
I'm planning to stick for now with x-cube ai since the new tool has a lot of bugs to be fixed .
My questions is what are the right versions of the software to use to get a computer vision (Yolo like) to work on my board ?
Thnx!
hamitiya
hamitiyaBest answer
Hello @whoami
Could you describe more what you mean by "a lot of bugs". For NUCLEO-N657X0-Q, I am not aware of any issues with the latest version of STM32Cube AI Studio.
For the S/W version, if you want to work with X-CUBE-AI (10.2.0), you will need
- ST Edge AI Core version 2.2.0
- STM32CubePrg 2.21
- STM32CubeIDE 2.1.0
You can also use models and deployment scripts from ST Model Zoo.
Best regards,
Yanis
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
hamitiya
hamitiyaBest answer
Hello @whoami
- STM32CubePrg 2.21
Best regards,
Yanis
whoamiAuthor
Hello @hamitiya !
Thank you for reply!
I think the problem is with CubeMX as the community mention.
I used CubeMX 6.16.0 with CubeIDE 2.1.0 and St edge ai 4.0 and i managed to work and the model is giving correct results.
Now I'm struggling with interfacing an STEVAL- 66GYM camera within my project.
I don't have a screen to plot the results on it , just want to store the camera data into memory array will be then passed to a NN model.
Is there any documentation or article to follow for the NUCLEO-N657X0-Q .
Thanks!
Julian E.
Hi @whoami,
We are glad to hear that you solved your first issue.
Regarding how to use a camera, we don't have a simple tutorial to do it but we have a lot of getting started / package that most likely achieve what you are trying to do.
STM32N6-AI | Software - STMicroelectronics
I would suggest looking at the image classification getting started, which should be the most straightforward one and probably the "x-cube-n6-camera-capture" that I don't know, but seems to be linked to your question.
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
whoamiAuthor
Hi @Julian E.  !
Thank you for your reply !
I consulted this repo https://github.com/STMicroelectronics/x-cube-n6-camera-capture/tree/main and using the binary i managed the camera to work as a webcame , but now i'm trying to build my own project but im finding a problems getting it to work .
I'm trying to find  what configuration should be done through reverse engineering the code of this project. However since this project implements a lot other topics (FreeRTOS , usb ...) im getting stuck within this code .
For now i managed i figured that i should use the pipe 1 for my project but still not getting how to configure these parameters .
I had also read this application note AN6211 but still not getting it right
is ther any simple project that i can consult !
Thnx!
