ksale.1
Senior II
June 22, 2024
CUBE-MX AI stm32f446 problem compiling
I've joined introductory imbedded AI course on Udemy, unfortunately it is more than 4 years old using AI pack version 3.4.0 and I cannot get support from the instructor.
Please find attached a presentation with screen shots of all steps used to generate the project and compiler messages after each corrective action until I can no longer do anything and stuck.
Thank you in advance
ksale.1
ksale.1Author
Senior II
June 22, 2024
ksale.1
ksale.1Author
Senior II
June 22, 2024
please find file compiler2.txt
ksale.1
ksale.1Author
Senior II
June 23, 2024
I've followed instructions in the following link:
https://community.st.com/t5/stm32-mcus/how-to-integrate-cmsis-dsp-libraries-on-a-stm32-project/ta-p/666790
and build project with the same errors as per compiler3.txt.
Then tried to 'clean' the project rather than 'build' and voila all errors disappeared as per attached file compiler4.txt. Is that it?
ksale.1
ksale.1Author
Senior II
June 23, 2024
I tried the project with AI 9.0.0, build without errors .(the code as generated without any modifications) copiler5.txt. The issue is then the AI 3.4.0 Pack, what versions should I use for compatibility with this Pack.
