May 20, 2025 6:07 AM UTC
stellarstudio debugging issue on SR5E1-EVBE7000P board
Hi Team,
I am facing to connect with SR5E1-EVBE7000P board. I give below the issue. Can anyone help me to resolve this issue
Error in final launch sequence:
Failed to execute MI command:
-exec-run
Error message from debugger back end:
Don't know how to run. Try "help target".
-exec-run
Erwan YVIN
May 20, 2025 2:04 PM UTC
Hello ,
Which version of StellarStudio and openocd do you use ?
COuld you check openocd version plugin ?
                 Best Regards
                          Erwan
sai1996Author
May 21, 2025 4:41 AM UTC
Hi Erwan,
I am using
Open On-Chip Debugger 0.11.0+dev-gf194ae73a (2023-03-03-09:26)
StellarStudio-7.1
Regards,
saikrishna.
sai1996Author
May 21, 2025 4:44 AM UTC
Can i get setup documentation SR5E1-EVBE7000P board with stellar studio and example code.
Erwan YVIN
May 21, 2025 9:03 AM UTC
Hello ,
we have updated the version into
$ ./openocd --version
Open On-Chip Debugger 0.12.0+dev-01351-gce9e33791-dirty (2024-11-21-12:34)
Check the document How to use OpenOCD and StellarLINK in StellarStudio.pdf inside c:\StellarStudio-7.1\openocd\docs\
For your information ,
StellarStudio 7.2.0 officially pushed (Compliant f... - STMicroelectronics Community
               Best regards
                               Erwan
sai1996Author
May 21, 2025 11:21 AM UTC
After installing stellar studio 7.2.0. I followed the documents. But Still I am getting this error
Licensed under GNU GPL v2
For bug reports, read
"http://openocd.org/doc/doxygen/bugs.html"
adapter srst delay: 100
Started by GNU MCU Eclipse
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Error: unable to open ftdi device with description '*', serial '*' at bus location '*'
best regards,
saikrishna.
Apr 30, 2026 12:05 PM UTC
Hi
Has there been any progress on this issue please as I have the same problem.
Many thanks in advance.
