Apr 23, 2026 6:07 AM UTC
Regarding Pin information and Pin configuration
1. Where can I find pin function list for SPC582B60E1CD00X MCU.
Package: eTQFP64
2. Suggestion on tool used to configure pins according to application and generate code.
Apr 23, 2026 6:44 AM UTC
Your question is a bit surprising, since such a controller is used only in an environment where the question does not arise. If there is already a decision to use exactly this MCU then I assume someone has an idea about the developing tools.
This forum focuses on STM32 with ARM Cortex processors. But you ask for a PowerPc based MCU (e200z). I am not aware of a more specific forum or community for this.
But anyway: a starting point is the documentation available at https://www.st.com/en/automotive-microcontrollers/spc582b60e1.html
Here you should find all documentation.
Rearding a development environment there should be a SPC5Studio available from st.com, which includes an eclipse based IDE and gcc cross compiler.
sanket471Author
Apr 23, 2026 9:19 AM UTC
Thank you I got the IO definition sheet. IO Definition sheet for SPC582B60E1CD00X 64 pin MCU which i was looking for.
Can you guide on how to decide pins for a pin. I am working on AVAS system design. Ex. If i want to assign I2c, I2s, SPI to MCU pins.
Andrew Neil
Apr 23, 2026 9:30 AM UTC
You mean an Acoustic Vehicle Alerting System ?
As previously noted, That's a safety-critical automotive system - not really suitable for a novice project!
Surely, you must have someone supervising you who can help with these basic questions?
mƎALLEm
Apr 23, 2026 9:13 AM UTC
SPC5 is an automotive product.
The question needs to be asked in "Automotive MCUs" forum board.
The post will be moved then ..
KTANG.9
Apr 24, 2026 1:55 AM UTC
We have a AVAS reference board and schematic - https://www.st.com/resource/en/data_brief/aek-aud-c1d9031.pdf
User manual - https://www.st.com/resource/en/user_manual/um2719-avas-architecture-based-on-autodevkit-stmicroelectronics.pdf
Sample project - SPC582Bxx_RLA_AEK_AUD_C1D9031 - Avas Compact - Test Application
This is found in the AutoDevKit IDE - https://www.st.com/en/embedded-software/stsw-autodevkit.html
Has graphical pinmap editor to configure the MCU pins.
Best Regards
Kong Choy
