Roger.ch
"Run-Simulator", Compiler, Where can I suppress the error "...may be undefined [-Werror=sequence-point]"?
  • February 6, 2023
  • 5 replies
  • 1835 views
TouchGFX 4.21.1
When compiling for "Run Simulator" I get the following error message:
Run Simulator
  Generate
    Wrote generated/simulator/gcc/Makefile
    Done
  Generate Assets
    make -f simulator/gcc/Makefile assets -j10 -Wno-error=sequence-point
    Reading ./application.config
    Reading ./target.config
    Done
  Post Generate
    touchgfx update_project --project-file=../EWARM/EVK101008AB.ewp --gui-group-name=Application/User/TouchGFX/gui --generated-group-name=Application/User/TouchGFX/generated && touchgfx update_project --project-file=simulator/msvs/Application.vcxproj && touchgfx update_project --project-file=../MDK-ARM/EVK101008AB.uvprojx --gui-group-name=Application/User/TouchGFX/gui --generated-group-name=Application/User/TouchGFX/generated
    Done
  Compile
    make -f simulator/gcc/Makefile -j10 -Wno-error=sequence-point
    Compiling gui/src/model/Model.cpp
    gui/src/model/Model.cpp: In member function 'void Model::tick()':
    gui/src/model/Model.cpp:26:13: error: operation on 'counter' may be undefined [-Werror=sequence-point]
       counter = (counter < COUNTER_PERIODE)?++counter:0;
    cc1plus.exe: all warnings being treated as errors
    generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/model/Model.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/model/Model.o] Error 1
    make[2]: *** Waiting for unfinished jobs....
    generated/simulator/gcc/Makefile:155: recipe for target 'generate_assets' failed
    make[1]: *** [generate_assets] Error 2
    simulator/gcc/Makefile:32: recipe for target 'all' failed
    make: *** [all] Error 2
    Failed
  Failed
Where can I set the switch "-Wno-error=sequence-point" so that the compiler does not define this warning as an error and aborts?
I don't want to resolve the warning, I want the warning to not stop compiling.
gbm
You mean you want to have an error in your code? Why not this (assuming that counter is not declared volatile)?
counter = (counter < COUNTER_PERIODE) ? counter + 1 : 0;
If it is volatile - rethink what you are doing.
KnarfB
Hope you understand that warning and better resolve it.
Look for a compiler option -Werror and remove that, or add -Wno-error=sequence-point.
See https://gcc.gnu.org/onlinedocs/gcc/Option-Summary.html for all details.
hth
KnarfB
ferro
ferroBest answer
Lead
February 6, 2023
Roger.ch
Roger.chAuthor
Thank you very much ferro.
I didn't feel like explaining to colleagues the difference between "++i", "i++", "i += 1" or "i = i + 1".
Sadly enough, GCC had to define a "warning" for this.
You saved me a lot of time and effort with your competent and solution-oriented answer.
Thank you very much!
ferro
Lead
February 8, 2023
Glad it helped !
