on the st8's that have a DAC, can 5VDC be applied to vref+? Or, is there some alternative method to get an output swing of 0-5V?
Yes, almost correct: the swing for 12bit ranges from 0...4095 which ideally creates an output voltage at the DAC of 0...Vref.
Please also note the values of possible errors listed in the data sheet: differential and integral non linearity, offset error, gain error, total unadjusted error.
And yes, a non-inverting opamp with a gain of (5V/VDDA) would do two things:
Good luck!
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
