STM32CubeProgrammerLauncher won't launch on Ubuntu machine
Hello all, i tried to search for a solution within the STM community but none of the solution helps.Please guide
I have using a STM32MP157F board. I have set the dev board according to the manual. I followed the instructions  in this guide to get me started on installing the programmer Getting started with STM32MP157x Evaluation boards: However, on launching the STM32CubeProgrammerLauncher I get the following error.
/home/STM32MPU_workspace/tmp/en.stm32cubeprg-lin-v2-16-0/jre/bin/java -jar STM32CubeProgrammerLauncher
/home/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-x.y.z/bin
CubeProgrammer version: 2.16.0
Path CubeProgrammer version: : /home/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-x.y.z/bin/version
Updater version:1.1.7
Analytics - Current Software Path: /home/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-x.y.z/
Exception in Application start method
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:382)
at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:321)
at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:893)
Caused by: java.lang.RuntimeException: Exception in Application start method
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:823)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$1(LauncherImpl.java:181)
at java.lang.Thread.run(Thread.java:750)
Caused by: java.lang.UnsatisfiedLinkError: /tmp/jna-2019579227/jna9078924855068839529.tmp: /tmp/jna-2019579227/jna9078924855068839529.tmp: failed to map segment from shared object
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1934)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1817)
at java.lang.Runtime.load0(Runtime.java:782)
at java.lang.System.load(System.java:1100)
at com.sun.jna.Native.loadNativeDispatchLibraryFromClasspath(Native.java:947)
at com.sun.jna.Native.loadNativeDispatchLibrary(Native.java:922)
at com.sun.jna.Native.<clinit>(Native.java:190)
at com.sun.jna.Pointer.<clinit>(Pointer.java:54)
at com.sun.jna.Structure.<clinit>(Structure.java:2130)
at com.st.controllers.MainWindowController.<init>(MainWindowController.java:205)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
at sun.reflect.misc.ReflectUtil.newInstance(ReflectUtil.java:51)
at javafx.fxml.FXMLLoader$ValueElement.processAttribute(FXMLLoader.java:927)
at javafx.fxml.FXMLLoader$InstanceDeclarationElement.processAttribute(FXMLLoader.java:971)
at javafx.fxml.FXMLLoader$Element.processStartElement(FXMLLoader.java:220)
at javafx.fxml.FXMLLoader$ValueElement.processStartElement(FXMLLoader.java:744)
at javafx.fxml.FXMLLoader.processStartElement(FXMLLoader.java:2744)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2534)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2448)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3251)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3212)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3185)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3161)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3141)
at javafx.fxml.FXMLLoader.load(FXMLLoader.java:3134)
at com.st.app.Main.openCubeProgrammmerWindow(Main.java:192)
at com.st.app.Main.start(Main.java:184)
at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$8(LauncherImpl.java:769)
at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$7(PlatformImpl.java:326)
at com.sun.javafx.application.PlatformImpl.lambda$null$5(PlatformImpl.java:295)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.javafx.application.PlatformImpl.lambda$runLater$6(PlatformImpl.java:294)
at com.sun.glass.ui.InvokeLaterDispatcher$Future.run(InvokeLaterDispatcher.java:95)
at com.sun.glass.ui.gtk.GtkApplication._runLoop(Native Method)
at com.sun.glass.ui.gtk.GtkApplication.lambda$null$10(GtkApplication.java:245)
... 1 more
Olivier GALLIEN
Hi @jlrstm ,
You might not use STM32CubeProgrammerLauncher file but STM32CubeProgrammer to launch the UI.
eg in
 /home/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-2.16/bin
./STM32CubeProgrammer
Hope it help
Olivier
jlrstmAuthor
Hello Olivier
Thank you for your response.
However when i try I still get the same error.
./STM32CubeProgrammer .
ERROR
./STM32CubeProgrammer: line 7: cd: /home/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-x.y.z/bin : No such file or directory
at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:767)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.UnsatisfiedLinkError: /tmp/jna-2019579227/jna4896057083018484687.tmp: /tmp/jna-2019579227/jna4896057083018484687.tmp: failed to map segment from shared object
at java.lang.Runtime.load0(Runtime.java:810)
at java.lang.System.load(System.java:1088)
at javafx.fxml.FXMLLoader.processStartElement(FXMLLoader.java:2707)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2527)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:2441)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3214)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3175)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3148)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3124)
at javafx.fxml.FXMLLoader.loadImpl(FXMLLoader.java:3104)
at javafx.fxml.FXMLLoader.load(FXMLLoader.java:3097)
... 1 more
Exception running application com.st.app.Main
A point to be noted is that error says that No such file or directory. To avoid this error, i did a manual cmd
java -Djdk.gtk.version=2 -jar "/home/STM32MPU_workspace/STM32MPU-Tools/STM32CubeProgrammer-x.y.z/bin/STM32CubeProgrammerLauncher"
ERROR THAT I GET IS:
Error: Could not find or load main class com.st.app.Main
Caused by: java.lang.NoClassDefFoundError: javafx/application/Application
Hi All,
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly.
Jake
ST Support
