2022-03-28 3:04 AM
Clearly, the angle brackets for the 'port' option are mismatched.
It should say:
port=<PortName>The error is repeated in UM2237 Rev 18 (the current version) - and note that the User Manual does not match the actual output:
2022-03-28 3:50 AM
Also, the documentation of 'noinit' is inconsistent with every other option taking a value:
To be consisten, that should be:
[noinit=<noinit_bit>]: Set No Init bits, value in {0,1} ..., default 0ie, angle-brackets around the value placeholder
