ark2
Troubleshooting CUBE Programmar Settings Change Error
  • March 29, 2024
  • 0 replies
  • 962 views
I briefly changed the option byte setting through CUBE Programmmer
It was changed well before, but I tried to change the DMEP setting and return it because I couldn't want it, but an error occurred and it is not changing
The error appears as follows, so please tell me how to fix it
18:26:25 : Error: Expected value for Option Byte "DMEP1": 0x0, found: 0x1
18:26:25 : Error: Expected value for Option Byte "DMEP2": 0x0, found: 0x1
18:26:25 : Error: Option Byte Programming failed Or modified by application after OB_LAUNCH
