FArdi.1
Sep 29, 2021 3:43 AM UTC
STM32CubeProgrammer 2.8.0 Automatic mode is not working
Using ST-link V3.
MCU: STM32L031
First programming was ok. After disconnecting and reconnect with second device, nothing happen.
0693W00000FAklrQAD.pngUsing same set of hardware, but changed software to ST-LINK Utility.
Result: ok. Automatically programmed the second device.
Oct 6, 2021 3:47 PM UTC
Hello @FArdi.1,
Try unplug the board every time or use STLink utility.
Try this and if this solves your problem please let me know.
Imen
FArdi.1
FArdi.1Author
Oct 7, 2021 1:08 AM UTC
Try unplug the board every time:
Reply: That's my main purpose of using automatic mode. I must unplug previous board, and plug the next one. I expected STM32CubeProgrammer detect automatically, but it didn't.
use STLink utility:
Reply: STlink utility worked fine as mentioned in original posting. I thought this software is replaced by STM32CubeProgrammer?
https://www.st.com/en/development-tools/stsw-link004.html
Oct 7, 2021 3:05 PM UTC
Hi @FArdi.1​
ST-Link utility is not recommended for new products.
Maybe you need to update the ST-Link Firmware !
Imen
KSchu.5
Visitor II
Mar 7, 2022 12:08 PM UTC
I have exactly the same problem, the automatic mode does not recognize the second device.
Is this a confirmed bug?
Tested with:
ST-Link/V3 (Firmware V3J8M3B5S1)
ALin.10
Visitor II
Mar 9, 2022 3:06 AM UTC
Tested with:
MCU:STM32G030
STM32CubeProgrammer 2.9.0
ST-Link/V2 (Firmware V2J39S0)
Jin.Ian
Aug 15, 2022 2:59 PM UTC
I use STM32G030. I have exactly the same problem. Stm32CubeProgrammer doesn't recognize the second device. Any solution by now?
Thanks.
Tesla DeLorean
Guru
Aug 15, 2022 3:53 PM UTC
CM0(+) devices can be particularly sensitive to speed.
If your interface doesn't connect NRST, a whole bunch of those methods won't be usable.
Discuss your priorities and expectations with your FAE, or sales rep.
JWieb
Aug 11, 2023 4:45 PM UTC
Bump. Would also like help with Automatic mode. First device works, disconnect is detected, but second device does nothing.
STM32CubeProg V2.9.0
STLINK V2J40M27
Piranha
Principal III
Aug 11, 2023 10:16 PM UTC
And why haven't you tested the latest versions first?
