SFI Via HSM
  • January 25, 2024
  • 1 reply
  • 774 views
Hello Everyone,
With STM32HSM -V2AE - 25
-> Flashed the firmware version1.0  for 10 numbers and will the remaining 15 counts supports to flash the updated firmware version 2.0?
-> If the firmware upgrade happened in field how does HSM support in that case.
Thanks In Advance
Surya S
1 reply
Aziz BRIGUI
Hello @Surya S
You can do this if you encrypt the second firmware with the same encryption key and nonce files (used to program the HSM).
I hope you find this helpful.
Aziz
