I installed STM32CubeProgramme twice but both times it shows the splash screen then exits. Anyone having a similar experience or know how to fix the problem? Thanks ya'lll.
DBenn.1311
DBenn.1311
Hi Oliver,
I found another question similar to mine with a lead to the solution. The solution was to uninstall all of my JDKk and Java 8 update 231, then install the cube programmer, then reinstall the Java update. Since then all is well.
Thanks for your response.
Dan
Olivier GALLIEN
On which OS are you installing CubePro ?
Did you refer to UM2237 for installation ?
Olivier
Olivier GALLIEN
DBenn.1311
Hi Oliver,
Dan
