Custom bootloader Desktop Application
vchau.2
Dear All,
I'm looking source code of STM cube programmer for Custom changes as per my Application,
Kindly suggest how to get source code of cube programmer(Uart programming mode)
Peter BENSCH
The STM32CubeProgrammer is not an open source tool, so the source code is not available.
If you want to program via UART, you can use the internal bootloader and the AN3155 as a basis for your own development.
Hope that helps?
Regard /Peter
