cube programmer - leave dfu
NBita.1
hi
in the previous tool DFude v3.0.6 we had a button called -leave dfu mode,
that button made disconnection and reset to MCU if you were connected with USB, so after flashing the MCU jump to application FW,
now in the cube programmer, we don't have this option, just disconnect, and then you need to manually reset the MCU,
overall we try also to do that from the USB_EXAMPLE from the API folder in the cube programmer file,but can't do reset from the usb , is there any way?
Christian N
Hello NBita.1,
Thank you for contacting STMicroelectronics.
Your post was escalated to ST Online Support Team for additional assistance.
Kind Regards,
Christian
ST Support
