TJone.3
Visitor II
April 15, 2022
Can I use *dfu files with the Cube Programmer? We have used dfuse in the past and it has worked will but the new tool (Cube) does not seem to handle the *dfu files. Is there an additional driver I need?
  • April 15, 2022
  • 817 views
MM..1
You dont need dfu files
Houda GHABRI
Hi @TJone.3​ ,
DFU files are not supported by STM32CubeProgrammer, only Dfuse is recommended in this case.
Houda
