Wrong USART3 pins on Nucleo-F756ZG
Kamil Duljas
Senior III
On my Nucleo-F756ZG, when I generate code for USART3 that's by default connected to ST-LINK , Cube sets pins for morpho connector (PB10 PB11) instead of alternate function (PD8 PD9). I also use Nucleo-L476RG and for this board, Cube set alternate funtion pin for Usart2 default connected to ST-LINK.
Dudo
16 REPLIES 16
Kamil Duljas
Senior III
@Ghofrane GSOURI​ ?
Dudo
Kamil Duljas
Senior III
@Ghofrane GSOURI​ ? Could you answer?
Dudo
@Sara BEN HADJ YAHYA​
Not sure whom to flags this with.
Needs some Board Level Awareness related to suggested pin defaults for peripherals. Will lead to less mistakes, and more code ​working on first try.
Hello @Community member​ ,
@Ghofrane GSOURI​  will investigate this issue and provide an answer asap.
Sara.
what's up?
Dudo
Ghofrane GSOURI
Hello @Kamil Duljas​
Sorry for the late response.
Your suggestion is submitted to dev team .
Internal ticket number: 151857(This is an internal tracking number and is not accessible or usable by customers).
I will keep you posted with updates.
Thx
Ghofrane
Thanks :folded_hands:​
Dudo
