WTieg.1
STM32H745 RMII and DP83822 Question
  • March 10, 2020
  • 8 replies
  • 4303 views
I use STM32H745 RMII and DP83822
To use CubeMx generate code for lwip, selected phy is LAN8742.
Modify the code
But can't make it work
Any body has the experience or some advice ?
Hope someone can help me.
WTieg.1
WTieg.1Author
Now I make DP83822 works. LED_0 is lighten
But the network can't work
RN.304
We are Using STM32H735 with DP83822HFRHBR we are not able to detect the PHY with the altered Cube MX code.
Please guide how to proceed.
Is there any modification required ?
Rajesh
alister
Senior III
March 11, 2020
After you've resolved your PHY problem, check out my bug-fixes and improvements to ST's STM32H7 ETH driver and lwIP ethernetif.c at https://community.st.com/s/question/0D50X0000C6eNNSSQ2/bug-fixes-stm32h7-ethernet
WTieg.1
WTieg.1Author
Hi Alister
Thanks for your answer.
I read the link, I find that ​v1.5.0 & v1.6.0 has the problem .
I use v1.7.0, this version still has the problem
Just replace the file is ok ?
alister
Senior III
March 12, 2020
Read the posts there carefully. Porting it to your software is technical and requires skill and care. If you use it, to assist other developers, please post a summary there confirming it's ok and/or any problems with it you'd had to solve. Thanks.
HVict
Hi WTieg.1
Have you succeeded in modifying the code to interface with the DP83822?
WTieg.1
WTieg.1Author
To Hvict
I solved the problem
But I don't know how to  submit my bug-fixes and improvements
alister
Senior III
July 21, 2020
Add "Bug-report" to your topic list, attach the fix, CC @Amel NASRI​, and search community for any updated "how-to" instructions.
IMor.1
Hi @WTieg.1​
I am going to use the same STM32H745 RMII and DP83822, Do you have an updated code ?
MSile.1
I'm facing the same problem: STM32H7 + DP83822...any updated code??
Can you please help us how to integrate DP83822HFRHBR with STM32H73 series MCU.
