Thon.1
stm32f103rct - mcu rs232 to 0x02 , 0x30 ,0x03 off / 0x02,0x31,0x03 on I don't know what the problem is. help me
  • December 23, 2019
  • 8 replies
  • 2035 views
#define MAX_DATA_LENGTH 50
#define STX   0X02
#define ETX  0X03
u8 g_u8Rs232TxBuffer[105] = {0};
u16 g_u16Rs232Tick = 0;
extern UART_HandleTypeDef huart1;
//(0X02, 0X03 0X30 , 0X11~ 0X18) OFF
//(0X02, 0X03 0X31 , 0X11~ 0X18) ON
u8 Rs232_DataReceived(u8 u8RxData[], u8 u8RxDataLength)
u8 u8Rdvalue = 0;  //ReceiveDataValue
u8 i=0;
u16 u16Temp =0;
if (u8RxData[0] )
u8Rdvalue = u8RxData[0];
void Fun_Uart1_RxReceived(u8 u8RxData)
static BOOL s_bDbgRxStartFlag = FALSE;
static u8 s_u8DbgBuffer[64] = {0};
static u8 s_u8DbgCount = 0;
int g_u8Dbg_RxBuffer[64] ={0};
if(s_bDbgRxStartFlag == TRUE)
s_u8DbgBuffer[s_u8DbgCount] = (u8)u8RxData;
s_u8DbgCount ++;
if(s_u8DbgCount >= 64)
s_u8DbgCount = 0;
else
if(u8RxData == 0x31)
else
if(u8RxData == 0x30)
s_bDbgRxStartFlag = TRUE;
s_u8DbgCount = 0;
void Rs232_SendData_(u8 Data)
huart1.Instance->DR = Data;
while(__HAL_UART_GET_FLAG(&huart1, UART_FLAG_TXE) == RESET);
Thon.1
Thon.1Author
I made a separate c file
Thon.1
Thon.1Author
0x02 0x30 0x03
receive
Confirm and is true
Send
Thon.1
Thon.1Author
also 0x02 0x31 0x03 equal
Tesla DeLorean
Guru
December 23, 2019
Sorry, we don't even know what the question is.
You're rambling incoherently.
Perhaps you could start from the beginning?
You'd want to wait on TXE before sending data, not after.
You want to read some pattern/sequence and then respond?
Thon.1
Thon.1Author
Receive (0x02 ,0x30 ,0x03)the data, check (0x02 ,0x30 ,0x03)the data and send it again if correct
Tesla DeLorean
Guru
December 23, 2019
Can you successfully receive any characters currently?
Probably the best approach would be to make a state-machine that progresses as you receive each successive character.
The USART IRQ Handler can fire for each character received.
