Fendo59
Sep 3, 2023 10:53 AM UTC
STM32CubeIDE & MX integrated
I have some problem with STM32CubeIDE, since when I start a new project everything works well as long as I delete the file:
"home/STMCubeIDE/workspace_1-13.1/.metadata/.plugins/.org.eclipse.e4.workbench/workbench.xmi".
However, when I exit the project, closing STM32CubeIDE, and I reopen it, recalling integrated MX, either a blank page or the MCU only is shown. I'm not allowed to do anything.
STM32CubeMX standalone works correctly, without problems.
I tried to find some solution online, nothing works but deleting the file indicated above and restart the project
Here's my system informations:
Computer HP HP 250 G5 Notebook PC
SSD 500 GiB
Memory 8.0 GiB
Processor Intel® Celeron(R) CPU N3060 @ 1.60GHz × 2
Graphics card Mesa Intel® HD Graphics 400 (BSW)
O.S. Ubuntu 22.04.1 LTS 6.2.0-31-generic #31~22.04.1-Ubuntu
GNOME version 42.9
Graphics system Wayland
Java version:
openjdk version "17.0.8.1" 2023-08-24
OpenJDK Runtime Environment (build 17.0.8.1+1-Ubuntu-0ubuntu122.04)
OpenJDK 64-Bit Server VM (build 17.0.8.1+1-Ubuntu-0ubuntu122.04, mixed mode, sharing)
STM32CubeMX version 6.9.1
STM32CubeIDE version 1.13.1
STM32CubeProgrammer API v2.14.0 | Linux-64Bits
STM32 Trusted Package Creator v2.14.0 STMicroelectronics
Thanks for any suggestion.
Fendo59
Fendo59Best answer
Sep 4, 2023 9:32 PM UTC
I will continue my work with release 1.12.1 while waiting for the solution to the problem of release 1.13.1.
Thanks for your help.
Issamos
Sep 3, 2023 11:45 AM UTC
Hello @Fendo59
I suggest you to Completely uninstall STM32CubeIDE and delete any remaining configuration files/folders before reinstalling (this post explain this operation). This will clean out any corrupted settings. Than reinstall it.
Best regards.
II
Fendo59
Fendo59Author
Sep 3, 2023 2:54 PM UTC
Thanks for the reply.
I've already uninstalled with a purge and manually deleted the rest, reinstalled three times without success.
Now I try to uninstall ALL STM32 packages.
I hope for better luck.
Thank you
Issamos
Sep 3, 2023 2:58 PM UTC
Uninstall all the STM32 SW and packages and than reinstall them well be a good idea I guess.
Best regards.
II
Fendo59
Fendo59Author
Sep 3, 2023 10:18 PM UTC
After the 8th uninstall and install (see image)
Issamos
Sep 3, 2023 10:24 PM UTC
Hope that works fine.
Best regards.
II
Fendo59
Fendo59Author
Sep 4, 2023 1:06 PM UTC
Don't work again.
I installed version 1.10.1 and it works fine. I want to try with 1.12.1
Issamos
Sep 4, 2023 1:11 PM UTC
Hope this works for you ☺️
Fendo59
Fendo59Author
Sep 4, 2023 2:23 PM UTC
Realese 1.12.1 works fine, 1.13.1 still doesn't work.
Can multiple releases coexist on the same computer?
Issamos
Sep 4, 2023 2:55 PM UTC
Yes, you can have multiple release in the same computer
Best regards.
II
Fendo59
Fendo59Author
Sep 4, 2023 4:39 PM UTC
Thank you very much.
Now I have 1.10.1 and 1.12.1, they work fine. 1.13.1 does't work :face_with_steam_from_nose:
If you want I can post the logs of 1.13.1
Issamos
Sep 4, 2023 4:42 PM UTC
Ok thanks.
Best regards
II
Fendo59
Fendo59AuthorBest answer
Fendo59
Fendo59Author
Sep 7, 2023 12:51 PM UTC
attached here are the two log files
