Problem with Code Generated by CubeMX (5.6.1) for STM32F103C8 microcontrollers ...
‎2020-05-24 12:38 AM
When I run code generated by CubeMX (version 5.6.1) using Atollic IDE or VisualGDB w/ VisualStudio and STlink as Segger or as STlink after first run that don't works well (Read Errors) I can't connect anymore the microcontrollers for debug (virually they are destroyed for debug) . If I write the code manually and in my old projects it never happens. Is it some declaration on some header? Can anyone help me?
- Labels:
STM32CubeMX
STM32F1 Series
‎2020-11-13 3:20 AM
The problem was resolved using the Reset Pin Connected during programming.
Previously I used to program the ST’s with Reset disconnected.
Ok, the code generated with STM32CubeMX apparently need the Reset connected.
I don’t know why this difference or not exist difference because the other processors was programmed using the Stlink on Nucleo Boards (and reset was connected).
Previously with code generated manually I never connected the reset pin to the programmer and I had not problems.
My problem was resolved.
Thanks for your interest.
T.Papageorgiou
Sent from Mail for Windows 10
‎2020-11-13 2:05 AM
Dear @TPapa.1​
Could please use the last version of STM32CubeMX, and can you share you .ioc file ?
Best regards,
Houssem
‎2020-11-13 3:20 AM
T.Papageorgiou
